Ratickle1
Jan 07, 2018Tutor
Ethernet conection to AC3000- X6S Extender
I'm trying to find out if the X6S can be connected with an ethernet cable but be used as an extension of the same SSID. I cannot find it anywhere in the documentation or online, or when I called support. Has anyone set one up using an ethernet cable to the extender and had the router and extender both use the same SSID for one seamless network?
- You are looking for Access Point mode.
http://www.downloads.netgear.com/files/GDC/EX8000/EX8000_UM_EN.pdfThanks, But I've read that part several times before posting and it is still unclear to me. It appears to me that when the extender is connected in access point mode it only works as an extender with a new SSID. You completely lose the seamless extension of the existing network. So, as you move from one end of the house to the other the device being used switches from one WIFI network to another. It appears, when I read it, the only way to keep a seamless network is to use it in the WIFI connection mode.
I hope I'm wrong, but that it the way it appears to me. If so, there is no reason to buy this latest extender unless you want to connect it wirelessly, which loses one 5g channel as it will be exclusively used to connect the extender to the router.
Am I missing something when I read it?
- You can change the SSID to match the existing network. See the section "Change the WiFi Network Name" in the manual.
