PWD
Aug 13, 2015Tutor
Ethernet Connected Wireless Extender
Hello, I am trying to find some info/recommendations on how to extend the wireless coverage in my house. I have a Netgear N150 wireless modem/router set up at one end of the house, and the si...
netwrks
Aug 14, 2015Master
Yes, the EX7000 also works in AP mode. The EX7000 will need to be ethernet connected to your router, using one of your wireless router ports.
You create SSID's just like your router, which can also be the same same as your wireless router. Use different wireless channels (2.4 and 5 ghz) than your wireless router on the EX7000. The EX7000 in AP mode, all the LAN ports can be used. All devices that connect to this AP (wireless or wired) can connect to the internet, if all your devices are cabled, and configured correctly.
PWD
Aug 14, 2015Tutor
Thank you very much for the information. It is exactly what I was looking for! Much appreciated.
Peter
