imalil
Apr 04, 2019Aspirant
ex 3700 Access Point setup
i want to setup the ex3700 as an access point and connect it to my roku via ethernet cable. I cannot figure out how to do this. Can someone tell me how to do this?
Thank you.
Have you successfully setup the extender yet?
If so, you simply plug in the ethernet cord from your roku to the extender. You will probably need to go through your roku's network setup all over again.
http://www.downloads.netgear.com/files/GDC/EX3700/EX3700_UM_EN.pdf
page 14
If you haven't setup the extender yet, start on page 10 and it walks you through setup.
Here's the webpage that has downloads/manuals/installation guides.
https://www.netgear.com/support/product/EX3700?cid=wmt_netgear_organic
- imalilAspirant
Thanks for the reply. I've been doing this for 3 days and am at the end of my rope. After I setup the ex3700 from page 10, at what point do i unplug the ext, take it out of my router area, take it to my roku, and plug the roku into the ext via ethernet?
Thanks.
You don't have to setup the extender via ethernet. You can do it over wifi. Unless you're planning on using it as a wired access point. Is your goal is this:
Router-->wifi-->EX3700-->wired connection-->roku
If so you can just go through the initial setup with the EX3700 over wifi. Once its setup, just plug in the roku, redo the roku's network settings from within the roku, and you should be good to go.
Here's a video of someone setting it up via the wps button. Starts about the 3 minute mark.
https://www.youtube.com/watch?v=SUC_1J5c0Xc
Once you have it setup, see how its working and if it's doing what you expect. If you're unable to go through the wps setup (easiest) follow the manual or easy setup guide. Its here:
http://www.downloads.netgear.com/files/GDC/EX3700/EX3700_EN_QSG_04_10Mar2015.pdf
There's many settings that you can change from channel selection to fastlane to optimize speed and latency. Read a bit through to manual to find what works best for you.
