arichter5109
May 31, 2015Aspirant
EX 6100 Ethernet port lights
On a new computer using Ethernet cable from computer to extender the port light flashes green and connection is fine. Is this correct? Old computer with same hook up flashed solid green, just curious...
Babylon5
May 31, 2015NETGEAR Employee Retired
Your text isn't entirely clear I assume the 'old computer' did not flash?
If you are referring to the computer end of the interface then the indication at LAN cards / Motherboard LAN ports can vary. Personally I prefer to see the interface flash when there is activity.
