arichter5109
May 31, 2015Aspirant
EX 6100 Ethernet port lights
On a new computer using Ethernet cable from computer to extender the port light flashes green and connection is fine. Is this correct? Old computer with same hook up flashed solid green, just curious...
brucefal
Jul 12, 2015Novice
I can't understand the answer. I have 2 EX6100's. The Ethernet port on one 6100 flashes green, about once every 10 seconds. The other is solid amber. What does each of these indicators indicate? Is one operating differently then the other?
Thanks for the response in advance.
