silverinofuno
Feb 06, 2018Tutor
Ex 6120 led always red
May ex6120 is a dice meters from router, but Led "Router" is always red. The product is working, internet is ok,but Led Red is a problem, i don'like It.
DexterJB
Feb 07, 2018NETGEAR Moderator
Hi silverinofuno,
1. Does the LED color change when you have the extender close to the router?
2. Is the router signal strong from where the extender is located? You can check using a mobile device.
3. What is the firmware version of the extender?
4. Have you tried resetting the extender?
Dexter
Community Team
riffraff72
Feb 08, 2018Aspirant
my extender ex6120 also stay red on the router light , the router is only one room away. How do I check the firmware, also my router is a netgear so it should work. My computer shows the extender is working but the light is still red. help
