silverinofuno
Feb 06, 2018Tutor
Ex 6120 led always red
May ex6120 is a dice meters from router, but Led "Router" is always red. The product is working, internet is ok,but Led Red is a problem, i don'like It.
DexterJB
Feb 07, 2018NETGEAR Moderator
Hi silverinofuno,
1. Does the LED color change when you have the extender close to the router?
2. Is the router signal strong from where the extender is located? You can check using a mobile device.
3. What is the firmware version of the extender?
4. Have you tried resetting the extender?
Dexter
Community Team
silverinofuno
Feb 09, 2018Tutor
I return EX6120 to shop, and buy EX6150. Now all LED green
- DexterJBFeb 11, 2018NETGEAR Moderator
Hi riffraff72,
Please provide answers to my previous inquiry.
You can check the firmware version by accessing the extenders UI. You can try using the IP address assigned to it by the router. You can find it on the router UI under attached devices.
Dexter
Community Team
- DexterJBFeb 14, 2018NETGEAR Moderator
Hi riffraff72,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
