RobinB
Aug 25, 2015Initiate
EX 6200 as ethernet wired access point
I have purchased an EX 6200 to use as a wired WiFi access point. Before I did this I called Netgear Support to make sure it supported this type of operation. I was assured it did. I was very clea...
nhann
Aug 26, 2015NETGEAR Employee Retired
Hi RobinB,
The EX6200 does not support AP mode to wire to your router.
How would you like to set up your network?
- RobinBAug 26, 2015Initiate
I fell a bit foolish really, it does work as an A/P.
I plugged the EX6200 into my router in one of the 5 ports and my PC into another and then turned the EX6200 on. I opened IE and it went straight to the EX6200 set up page.
It had a quick look at how it was connected and up popped two boxes "EXT" and "AP". I ticked AP and then went on to set up SSID, encryption, passwords etc...
Works well
Thanks
- nhannAug 26, 2015NETGEAR Employee Retired
Sorry for the confusion. Glad you got it working!
- jpmerronOct 30, 2015Aspirant
I am using the EX 6200 as a wired access point but it seems devices connected to the EX 6200 access point cannot communicate with devices connected directly to the router - even though they are on the same subnet?
For example if I ping a device on connected to the router (on ip address 192.168.1.12) from my macbook connected to the EX 6200 (on ip address 192.168.1.45) there is no reply. But it works OK if I connect the macbook to the router's wireless newtork (on ip address 192.168.1.45 ).
Have you seen this issue?
I am running Firmware Version V1.0.1.60_1.1.98.
There is a later version but when I installed it the GUI was different and I couldn't see an option for Access Point(Wired) so I down graded again.
Any help would be appreciated.
- JuanchoNov 15, 2015Aspirant
Hi,could you walk me step by step to do set up the ex6200 as an acces point please.
- nhannNov 16, 2015NETGEAR Employee Retired
Hi Juancho,
We will first start by resetting to Facotry defaults.
Then set up the EX6200 as an extender (IF you are not on firmware 1.0.3.68_1.1.104 then you will not necessarily have the Access Point option yet).
Then update to the latest firmware and reset the EX6200 back to defaults. Then setup the EX6200 as an Access Point
Let's start with a factory reset on your EX6200.
- Power on your EX6200.
- Insert a straightened paper clip into the hole of the Restore Factory Settings button and hold it for about seven seconds
- Release the button. The extender resets and restarts. This process takes about one minute
Now on your computer, connect to the EX6200's WiFi network ----> "NETGEAR_EXT"
Disconnect your computer from any other Internet networks
(for example: if you have an ethernet cord connecting your computer to the Router, disconnect this ethernet cord)
Then on your computer, open up a Web Browser and go to mywifiext.net or 192.168.1.250
Set up your network.
Once setup is complete, connect to your new Extender WiFi network.
(For example: the router network name is MYHOME, then your Extender network name may be MYHOME_EXT)
Now go back to mywifiext.net and update your firmware.
See page 80 of 124:
http://www.downloads.netgear.com/files/GDC/EX6200/EX6200_UM_09Jan2015.pdf
You have the option of Automatic Update or Manual Update.
Once the update is complete, Factory Reset your EX6200 again. Then on the new setup screen you will see:
