klt777
Dec 09, 2022Aspirant
EX-7700 is on but nobody is home, sometimes.
Auto dealer Service Dept. - along with their personal smartphones use laptops to diagnose vehicles. They connect to a Netgear EX-7700 Ext which is Ethernet wire connected to a Spectrum (cable interne...
klt777
Dec 14, 2022Aspirant
1st thank you for your feedback and recommendations.
Current status; Back up operational and monitoring via service bay users. So the jury is out until maybe Friday but next week would afford better sampling & averages.
I've attached some pics of the settings which brings me to a gray area. I reset the unit while it was on by holding in the Reset button for around 8 seconds when I noticed the LEDs changing. It came back up with no settings saying it needs to be set up. Once I clicked on Access Point it filled in the rest with previous settings. Not sure what to make of that but it works left it.
Dec 15, 2022Guru - Experienced User
Looks pretty solid and like its working. Hope it stays working.
The one thing you might look at changing is the one 5ghz channel is set on a dfs channel. If you have anything broadcasting on dfs channels in your area, it can cause it to drop for a period of time as it changes to a none dfs channel. You might just set it to one.
