JonHewitt
Oct 25, 2018Aspirant
EX1600 Extender pushing out incorrect IP for network
Following troubleshooting attempted so far: restore to factory settings, ensure no other wifi booster/extenders etc operating, situated extender next to router (192.168.0.1), cleared router tables o...
schumaku
Oct 27, 2018Guru - Experienced User
The extenders only issue addresses by DHCP while it's not configured and associated successfully to a "master" WiFi router or the mesh.. This is required for the initial set-up as well and to allow a management access if the connection is lost.
JonHewitt
Oct 27, 2018Aspirant
The extender had been successfully linked with a 'master' router, but are you suggesting that it had possibly become unlinked at some point and then begun to send out it's own IP addresses (under it's own DHCP)?
- schumakuOct 27, 2018Guru - Experienced User
Yes. And I'm pretty much convinced there is not much of a difference on the LEDs while the EX6100 (not EX1600, right?) in "config" mode.
- StephenBOct 27, 2018Guru - Experienced User
Yes, it will do that. It's needed in order for you to reach www.mywifiext.net.
