lmartin888
Sep 25, 2018Aspirant
EX2700 - Connectivity issues with Devices
Just tried to set up my extender. 3/4 of the lights are green... Power light is green, WPS is green, and Router is green, but device will not light green, it doesnt light up at all, even red. When i ...
Sep 26, 2018Guru - Experienced User
If you are seeing NETGEAR_EXT, then join that (it should be open). Then complete the setup by browsing to mywifiext.net.
If you aren't seeing that, then reset the extender and try again.
- lmartin888Sep 27, 2018Aspirant
Not seeing any option for an EXT network, my own or the netgear one. I have reset to factory settings 3 times.
- StephenBSep 27, 2018Guru - Experienced User
I think something is wrong with the extender hardware.
If this is a new purchase, see if you can exchange it with the seller. If that is not possible, you can do an RMA through netgear support (my.netgear.com).
