thurlow39's avatar
thurlow39
EX2700 BT Home Hub 5 no internet
Hi, I have set this extender up on my network. Everything seems to be connected properly. I am trying to connect my phone to the extended network. I have set this up at mywifiext.net and it says everything is connected and the phone detects the connection and says it's connected but when I try to use the internet the pages wont load and there is no internet.
Has anyone got any ideas?
1 Reply
  • OK, i've resolved this problem now. I spent 3 hours researching security settings and ip addresses on my router with no luck. As a last resort I turned the router and extender of at the mains and rebooted. This has fixed the problem. I have no idea why it would not connect to the internet before but hopefully this simple solution may help others with the BT Home Hub 5.
