Essgee1952
Jun 23, 2018Aspirant
EX2700 Can't log in to update firmware
I go to mywifiext.net and it asks for a user name and password which I don't have. Nowhere is there an option to reset anything. I tried the same login as my Netgear account, but it won't accept it.
- Jun 25, 2018
Thank you DexterJB, but the only login I created is for netgear.com and it won't accept that. No, there is no forgot password button or option. There are NO other options available, just the message that the login is incorrect. But, I dug deep into the documentation and found that it takes user name "admin" and "password," which worked. This is to update the firmware, which I was finally able to do.
DexterJB
Jun 25, 2018NETGEAR Moderator
Hi Essgee1952,
Welcome to the community!
1. These are the logins that you have created during setup.
2. There is a ""Forgot password" option available that requires you to answer security questions that have been setup.
3. If it is an option, a factory reset is something to consider.
Dexter
Community Team
- Essgee1952Jun 25, 2018Aspirant
- DexterJBJun 25, 2018NETGEAR Moderator
Hi Essgee1952,
Thank you for the update and confirmation. Glad to know you got it working.
Dexter
Community Team
