wesbeltz's avatar
wesbeltz
EX2700 Can't log into the router
I've just done a factory reset because I installed the latest firmware. I've connected to the extender's network and it prompted me to input my e-mail address, a password, and two security questions. I did that. It returned me to a login screen, asking for my e-mail and the password I just created. I am positive I am entering my e-mail and password correctly. When I enter them, the screen refreshes back to the same login screen. There is no message about my password being incorrect. If I click on the password help option and answer both security questions, I can verify that I am not entering my e-mail or password incorrectly. I have gone through two rounds of doing a factory reset, entering my e-mail and creating a password, and both times it won't take me past this login screen. This is making it impossible for me to setup the extender.
  • StephenB's avatar
    Are the email address and password the same as the ones you were using before?
    • wesbeltz's avatar
      wesbeltz
      Yes, the e-mail and password are the same ones I used before I installed the firmware and did the factory reset.
      • StephenB's avatar
        Do you have an ad blocker or internet security software running on the PC that might be getting in the way?
