blargh
May 12, 2016Aspirant
EX2700 device connection problem (failed to obtain ip address)
I set up the extender without too much trouble. It was working for a bit to connect to my mobile phone. However, now my phone can't successfully connect to the ext network. It gives the error "failed ...
DarrenM
May 18, 2016Sr. NETGEAR Moderator
Hello Blargh
It just may of needed some resets is this a on going behavior?
DarrenM
blargh
May 20, 2016Aspirant
I've tried resetting it, but the behavior is on-going.
- DarrenMMay 25, 2016Sr. NETGEAR Moderator
Hello blargh
You may need to change the wireless channels on the extender or your router to get better signal. also you may want to try and move the extender a little closer to the router.
DarrenM
