ARG
Mar 12, 2016Aspirant
Ex2700 doesn't work
I have the EX2700 which I bought a few months ago but never got it to work with my DGN3500. All the devices kept dropping connections to both the wifi networks. I switched off Ex2700 and did not turn ...
ARG
Mar 16, 2016Aspirant
Hi Darren
What channels should I be using on both the devices?
Thanks
Thanks
- DarrenMMar 16, 2016Sr. NETGEAR Moderator
This just depends on the area we have a app on android that you can download to help figure out what the best channel to use in your area. It is called netgear wifi analytics and if you have apple search for the wifi analytics app should be able to find a free one it will tell you what the least used channel is that is the one you want to set your devices to.
DarrenM
