wesbeltz
Nov 21, 2018Aspirant
EX2700 Extremely slow after firmware update and factory reset
Today I updated my wifi extender to the latest firmware. I did the factory reset as recommended. Now I'm getting extremely slow speeds with it. Earlier today I was getting download speeds around 3.5 ...
DexterJB
Nov 23, 2018NETGEAR Moderator
Hi wesbeltz,
Welcome to the community!
1. Please indicate the exact firmware version of the device.
2. Does the issue persist on all the devices that connect to the extender?
3. What is the status of the extender LED's?
4. Is the extender getting a good signal from the router where it's located?
Dexter
Community Team
- wesbeltzNov 24, 2018Aspirant
Firmware version: 1.0.1.52
It's slow for all connected devices.
The extender's LEDs are all green and indicate a device is connected.The extender is getting a good signal from the router. I checked by moving a wifi connected device right next to the extender and running a speed test on the router's own network.
- StephenBNov 25, 2018Guru - Experienced User
Can you try connecting something to the EX2700's ethernet port, and test the speed there using speedtest.net?
- wesbeltzNov 26, 2018Aspirant
When I plug my laptop into the ethernet port and goto speedtest.net and try to run the test, it says Latency Test Error in big red letters. Other websites load up fine while connected to ethernet.
