wesbeltz
Nov 21, 2018Aspirant
EX2700 Extremely slow after firmware update and factory reset
Today I updated my wifi extender to the latest firmware. I did the factory reset as recommended. Now I'm getting extremely slow speeds with it. Earlier today I was getting download speeds around 3.5 ...
wesbeltz
Nov 26, 2018Aspirant
When I plug my laptop into the ethernet port and goto speedtest.net and try to run the test, it says Latency Test Error in big red letters. Other websites load up fine while connected to ethernet.
Nov 26, 2018Guru - Experienced User
Usually that means one of their servers has gone down. Can you try the test again?
- wesbeltzNov 27, 2018Aspirant
Okay, I finally got the speed test. With it plugged into the extender via ethernet the download is about 1.5 Mbps. Better than 0.5, but still completely dissatisfactory.
Also, I just tried moving the extender to an outlet that was much closer to the router, and it got the same dismal speed of 0.5 Mbps. I'm beginning to think I just got a dud, or the thing is in the process of dying.
