glurbix's avatar
glurbix
EX2700 factory reset fails? -- can't get to new device prompt or login on mywifiext.net
I have three of these and want to repurpose them in a revised network.  After factory reset, only one of them behaved like a "new" product when connecting to it online, asking me to create a username...
  • glurbix's avatar
    glurbix
    Nov 01, 2017
    Thanks for this suggestion! Should have updated the query: I had simply misread the factory default login / pw printed on the actual extenders (small print!) and was finally able to get into them on mywifiext.net when I noticed, and updated firmware, and all are functioning now as I would want. So, problem solved.
