treatssquire's avatar
treatssquire
EX2700 Keeps asking me to sign in
I am having issues with my EX2700 after the latest firmware update. It worked fine the first day and the next day it asked me to sign in to the network. Now I get it connected but then for some reaso...
  • DarrenM's avatar
    Mar 30, 2016
    Hello treatssquire
    I would try to factory reset the device and do the setup again also tell your devices to forget the old network then try to connect again. Makesure the extender does not have the same SSID as your router.
    DarrenM
