Salvatretzzo
Dec 12, 2016Aspirant
EX2700 low speed
Low speed Hi yesterday recive this product, my home speed connection is 100/10 Mbps, the router is in the living room and wifi extender in my room(look the screen I dont have my pc right now) the r...
Salvatretzzo
Dec 13, 2016Aspirant
someone can help me?
DarrenM
Dec 15, 2016Sr. NETGEAR Moderator
Hello Salvatertzzo
If your extender is connected via wireless then you will not get the same speed as you are getting from your main router. The signal can be up to half the speed loss of your main router. Also the materials in the home and wifi interference can cause speed loss.
DarrenM
