mspohr
Oct 27, 2015Tutor
EX2700 N300 Can't connect to Internet
I've been through the setup of my EX2700 N300 several times after factory resets. Each time the "genie" pops up and I go through the steps to connect to my WiFi and it assignes the _EXT name to it th...
gsus
Jul 09, 2016Aspirant
Similar thing to me:
Afert some time working perfectly this morning the Ex2700 has decided to go on holidays.
Factory Reboot and resetup. Everything seems to be perfect, green in the mywifiext and in the device. My laptop and mobiles can connect to the device but then they don't have internet access. I connect through the router though perfectly, that has had no changes at all.
The router is a livebox from orange
How to fix this?
- DarrenMJul 12, 2016Sr. NETGEAR Moderator
Hello gsus
Do you happen to use mac filtering at all on the router if so I would check to see if the extender is setup properly in those settings so it is allowed to connect.
DarrenM
