mspohr
Oct 27, 2015Tutor
EX2700 N300 Can't connect to Internet
I've been through the setup of my EX2700 N300 several times after factory resets. Each time the "genie" pops up and I go through the steps to connect to my WiFi and it assignes the _EXT name to it th...
jbtibor
Oct 03, 2016Initiate
The same happened to me without any changes to extender or router. I tried with Android phones and Windows 10 laptops.
The reason for not working is that devices connected to extender are not assigned an IP address. If I switch a device to use static IP it has internet, otherwise it hasn't. I have the latest firmware on extender (1.0.1.10) and on router. I have a TalkTalk router but doesn't depend on router, same error with a BT router and an Asus router too. None have MAC filtering, all have DHCP enabled and all devices connect to internet when using the router. Had a few factory resets, deleted saved wifi networks on devices, didn't help.
