LordanJuicy
Sep 24, 2018Aspirant
EX2700 N300, connected to internet but not device light at all
Hi there,
I have recently moved into a new house and have brought along the same wifi extender which i used at my old house which worked perfectly. However when i connect this extender to the r...
Sep 24, 2018Guru - Experienced User
LordanJuicy wrote:
the device light not being switched on
Well, the device LED is only lit when a client device is connected. I don't own this particular extender, so I am not sure what the LED behavior is when only a client ethernet device is connected. It might also depend on the power management settings in the PC.
What color is the router LED on the extender?
LordanJuicy wrote:
the internet here is very fast
What speed is your internet service?
LordanJuicy
The router LED is lit Green, all LED's are lit green apart from the device, which only goes green when i connect my phone.
I used this extnder in my old house and the device LED lit up straight away when i connected it to the same computer.
It is stable at 54 megabits per second
- StephenBSep 24, 2018Guru - Experienced User
What is stable? Wifi?
What speed is your internet service (from your ISP, not your wifi speed).
Good to know. Did you try using a different ethernet cable?
- LordanJuicySep 24, 2018Aspirant
Yes the wifi seems to be stable but without a proper link it drops all the time.
I am not sure what the isp is, how do i find that out? The wifi had been put in place before i had arrived here and was not told much about how fast it was.
Yes i have tried that and so far nothing
LordanJuicy wrote:I am not sure what the isp is, how do i find that out?
Are you paying for your internet? If so, whom are you paying, and what service level are you paying for?
Another approach is to browse to speedtest.net using a PC connected to an ethernet port in your router.
