chandlerna's avatar
chandlerna
Follower
Aug 22, 2018
EX2700 N300 WITH CENTURYLINK ACTIONTEC Q2000
I just purchased an EX2700/N300 to extend the range of my router. I am using CenturyLink DSL, so my modem/router is a CenturyLink Actiontec Q2000. I am getting all the green lights on my N300. I am a...
  • DexterJB's avatar
    Aug 23, 2018
    Hi chandlerna,
    Welcome to the community!
    1. Most, if not all, NETGEAR extenders work with most routers. You may check with your ISP if there are any compatibility issues.
    2. Does the extender show up as a connected device on the router's UI with an assigned IP?
    3. Please make sure there is no MAC filtering or similar that may prevent the extender from connecting to the router.
    Dexter
    Community Team
