Donaljb06
Feb 12, 2022Tutor
EX2700 N300 wont connect to my router
Ive had this extender a few years now and have had no problems with it. However recently it stopped working. It refuses to connect to my router and the router LED will not turn on. Ive tried everythin...
Donaljb06
Feb 12, 2022Tutor
Hi, im connecting to a Virgin media hub 3.0
Feb 12, 2022Guru - Experienced User
I see a lot of posts with issues setting up extenders on that hub.
You can try reading through this and seeing if it helps.
I've seen others that had to set a static ip address in the hub for the extender.
