Shadow31
Jan 13, 2019Aspirant
EX2700 router light won't turn on
I'm not tech savvy at all, but have followed directions exactly. Plug in, power light turns green. Press WPS light, it blinks green for a while, press WPS on my router, then it blinks a while and com...
- Jan 17, 2019
Hi Shadow31,
Reset the extender and join the NETGEAR_EXT wifi network. After you connect to it, browse to www.mywifiext.net using a web browser and follow the setup instructions. Please let us know the outcome.
~Christian
Christian_R
Jan 17, 2019NETGEAR Employee Retired
Hi Shadow31,
~Christian
- Shadow31Jan 17, 2019Aspirant
Thanks Christian. I went to the website and was able to complete the process. I can now stream movies without hiccups - Thanks!
- Christian_RJan 17, 2019NETGEAR Employee Retired
Shadow31 - Glad I was able to help! Have a great day!
