NeilMM
Feb 25, 2021Aspirant
EX2700 setup - unable to press 'next' button
I am setting up an extender after factory reset.
I connect to the extender wifi and open up mywifi.ext.net to set up account
I complete email, password and security question fields but am then unable to proceed. The 'next' button is grayed out. I can only click the 'back' button next to it.
Help much appreciated.
- did you check to ensure the fields were properly done? like making sure the password met minimum requirements?
1 Reply
- plemansGuru - Experienced Userdid you check to ensure the fields were properly done? like making sure the password met minimum requirements?
