Jake7284
Nov 29, 2017Aspirant
EX2700 suddenly won't connect to router.
So my EX2700 has been working perfectly for 6 months without any issues at all, but I recently messed with the settings online, changing the extender password. It worked fine after that too until it ...
Jake7284
Dec 05, 2017Aspirant
This is the error message that comes up whenever I try to connect my extender using the Genie, even though it has previously worked for a good 6 months with no errors... It just doesn't seem to connect to the router no matter what I try, and the password is definitely correct. Any ideas on what to do to fix it? It's really starting to frustrate me and I don't know whether I should just buy another one when the same problem may persist.
DarrenM
Dec 08, 2017Sr. NETGEAR Moderator
Have you tried a different web browser when you factory reset and go through the setup process again?
DarrenM
