Nvogler's avatar
Nvogler
Guide
Feb 14, 2023
Ex2700 won’t connect to internet
I have tried everything. I have reset the router multiple times, tried to connect using mywifiext as well as using WPS. Both ways will get me to the point where the wifi extender is set up, but once I...
  • plemans's avatar
    Feb 15, 2023
    Your first post made it seem as if you can connect to the mywifiext address
    One thing to try is after its setup, log into your router and check its attached devices page. See if the extender is connected here and what its ip address is. Use that ip address to try to connect to it.
