Nvogler
Feb 14, 2023Guide
Ex2700 won’t connect to internet
I have tried everything. I have reset the router multiple times, tried to connect using mywifiext as well as using WPS. Both ways will get me to the point where the wifi extender is set up, but once I...
- Feb 15, 2023
Your first post made it seem as if you can connect to the mywifiext address
One thing to try is after its setup, log into your router and check its attached devices page. See if the extender is connected here and what its ip address is. Use that ip address to try to connect to it.
Feb 15, 2023Guru - Experienced User
Nvogler
Feb 27, 2023Guide
I think that did it. Got the IP, logged in, the automatic firmware update indicated it was updated (not sure if that was the case). Manually uploaded the newest firmware file and went through the smart setup again after it rebooted. I can connect again and am getting internet finally. Hopefully it continues to work! Thank you for your help!
