Swenerd
Mar 11, 2016Follower
EX2700 Won't connect to any devices
I set up the extender and connected devices just fine. The next day, nothing will connect. I reset the extender to factory settings, and re-setup, still nothing. Green light for link between router and extender. MAC filtering on router is off. Ext shows up in available connections. When I select it, connection icon spins and spins, but won't connect. Apple products (iPhones and iPads) trying to connect.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Swenerd
have you told your apple devices to forget the network for the old networks that the apple device was connected to.
DarrenM
