Twayscyc's avatar
Twayscyc
ex2700 won't connect to mywifi.net after router change
Was working perfectly before router change. Power, Device & WPS lights all Green....Router light Red... All devices connect to WiFi Extender wifi network and Internet but None will connect to Extender via mywifiext. Want to check version & possibly update firmware
  • schumaku's avatar
    schumaku
    Of course - the extender must be linked to the new router resp. it's different SSID (wireless network name) and security key (wireless password).
    The extender must be re-configured like every other wireless device if the network has changed. Don't know why, one day I will understand why people don't change the new wireless router to the "old" network name and security - it could be so easy...
    Of course again. At this state, that's about as useful as a network cable just connected into the computer or a switch - without a connection to the router, there is no network, no Internet, ...
    Almost - you need to factory reset the extender and reconfigure it from scratch following the fine documentation https://www.netgear.com/support/product/EX2700.aspx#docs
    • Twayscyc's avatar
      Twayscyc
      Network name & password is the same. All devices Have Internet & are connected to network_ext......     But I can't connect to mywifiext on any device with any browser!
      • Twayscyc's avatar
        Twayscyc
        Even when connected with an Ethernet cable Still will Not connect to extender interface
