Kundtz
Sep 30, 2018Aspirant
EX2700/N300 wifi extender isn't doing the job.
The problem was that NETFLIX on my iPAD keeps losing connectivity when being used in the basement. The VERIZON router is upstairs. I thought that the NETGEAR EX2700 would be the solution. I placed th...
schumaku
Oct 01, 2018Guru - Experienced User
Ensure the EX2700 does run current firmware - EX2700 Downloads
What does the extender show for the uplink to the router - signal and link speed? Here a similar (slightly older) N300 unit (same image added as attachment):
- KundtzOct 01, 2018Aspirant
Hello. I have updated to the latest firmware version. Here is the genie screenbelow. Iam still having problems connecting to the network, even though getting three bars. Thank you for your response.
- StephenBOct 01, 2018Guru - Experienced User
You are showing only the extender network. Can you also tell us about the extender->router link quality? Posting the same page as schumaku did would help (using the web browser to reach the extender web ui, not the app). Also, what color is the router link LED on the extender?
Also, is the iPad actually dropping the connection, or is the problem that Netflix streaming is stalling? Have you tried running a speed test?
