cpalmas
Nov 25, 2018Aspirant
Ex3110 xbox one connectivity
My extender was working great until a few days ago. It disconnected my from my xbox one and now won't reconnect. Any time I try to connect, i get a message saying my xbox can't get an IP address. I've...
Nov 26, 2018Guru - Experienced User
What is the status of the four LEDs (Power, Router, WPS, Device).
Are you able to connect to the extender network with other devices?
cpalmas
Nov 26, 2018Aspirant
The LEDs are all green. I'm able to connect my phone and smart tv to the extender, and I'm able to connect my xbox to my original network. It's jus not as strong which is why I bought the extender
- StephenBNov 26, 2018Guru - Experienced User
So you can connect with other devices, but the xbox isn't seeing the extender wifi???
- cpalmasNov 26, 2018AspirantThe extender wifi comes up as an option to connect to, but after trying to connect for several minutes, I'll get a message saying the xbox can't find my IP address
cpalmas wrote:
The extender wifi comes up as an option to connect to, but after trying to connect for several minutes, I'll get a message saying the xbox can't find my IP addressOk. But you aren't seen that with the other devices, just the xbox. FWIW, I think the error is really saying that the xbox can't get an IP address (which it normally gets from the router).
I suggest that you try rebooting the network. Turn off the router, extender, and xbox. Then power up and boot the router, followed by the extender, and finally the xbox.
