Jorge1951
Jan 05, 2017Follower
EX3700 - keeps connecting to WiFi Range Extender instead of primary network
My new EX3700 - AC750 WiFi Range Extender does not connect to my home network. The existing router does not allow me to make the point 2 of the manual .... "press the WPS button on your router or acc...
DarrenM
Jan 09, 2017Sr. NETGEAR Moderator
Hello jorge1951
You will have to do the manual setup by connecting to the extender via the default password and then go to www.mywifiext.net and then should take you through a wizard to set up the device.
DarrenM
