Palcone's avatar
Palcone
Ex3700 cannot connect to ps4
So I recently bought the ex3700 to able to get better connection in my room for my PlayStation. It works perfectly for my iPhone however my PS4 cannot connect to it or even detect it.
At first it can’t find the IP address so I entered them manually but after that it can’t connect to the internet.
I don’t want the hassle of returning the product so any help of solving the problem would be very helpful.
Thanks in advance.
  • plemans's avatar
    Firmware on the extender?
    What router are you connecting it to?
    Its ONLY the ps4 that's having issues? All the other devices connect without issues?
    Are you running the extender in fastlane mode or standard extender mode?
    the ex3700 has an ethernet port, have you tried hardwiring in the ps4?
    • Palcone's avatar
      Palcone
      The extender is on the lastest firmware
      I am trying to connect to my gf SKY router
      The problem is that the 2.4GHz has no connection to the internet. Only the 5GHz has connection and my PlayStation is the first gen PS4 which doesn’t support 5GHz only 2.4GHz.
      Yes the extender connects to my iPhone and my gf iPhone perfectly in the 5GHz bandwidth but not the 2GHz.
      I am running it on the standard extender mode.
      And I’ve not tried the Ethernet cable as I don’t have one.
      • plemans's avatar
        i would try redoing the setup process using the smart connect wizard and not wps. Maybe the 2.4ghz wasn't set right.
