Enzuigiri
Jun 07, 2024Initiate
EX3700 Cannot Update Firmware
Hi, can anyone assist me with the update of firmware for the EX3700?
I have seen many people have issues before, and I am finally getting round to it now as well out of date, but cannot update as the extender returns that the firmware file is invalid.
I have done the usual stuff of downloading the zip from netgear, unzipping so that I have the .chk file available but the extender doesn't like it no matter which release I use.
I have looked at solutions online but nothing works so if anyone knows what the fix is I would be grateful otherwise this will have to go in the bin for an alternative brand as armour reports huge security flaws
Thanks in advance
#ex3700
I have resolved the issue myself. It turns out that if you go into the Netgear support site and look up your device (EX3700) it suggests that the firmware is a .chk file. The documentation also says this is correct.
However, if you login to my netgear and click on your product the download is an .img file which works - just a bad support site I guess.
what firmware version are you on?
You can use the snipping tool to take a video of what you're doing. Thats sometimes faster and allows us to see whats happening/going wrong.
- EnzuigiriInitiate
However, if you login to my netgear and click on your product the download is an .img file which works - just a bad support site I guess.- plemansGuru - Experienced User
glad you got it working. Its usually either a .img or .chk
either work
