Hbterrell
Aug 29, 2018Aspirant
EX3700 connected but no internet
I’m connected but says no internet connection. What do I do?
DexterJB
Aug 29, 2018NETGEAR Moderator
Hi Hbterrell,
Welcome to the community!
1. Please make sure that you go through the setup process as described here.
2. What is the status of the extender LEDs?
3. Have you tried connecting another device?
Dexter
Community Team
- DexterJBSep 02, 2018NETGEAR Moderator
Hi Hbterrell,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- HbterrellSep 03, 2018AspirantDexter,
I am it says it has a bad IP address.?? Normal wireless works fine, but when I try to switch over to use the EX3700 WiFi it connects no internet. When you run troubleshooting it says bad IP address.- adrianGarci1105Apr 13, 2019Aspirant
EX7500
- DexterJBSep 05, 2018NETGEAR Moderator
Hi Hbterrell,
1. What is the status/color of the extender LEDs?
2. Please make sure that the extender is still close enough to the router for it to get a signal.
3. Please make sure that the extender appears as a connected device on your router's UI.
Dexter
Community Team
