Mutedname
Jun 01, 2023Follower
ex3700 device light
so my ex3700 worked for me for about a year prior to the last week and now it still feeds a signal to my pc will wired in but the device light will not comeback on ive restarted the system unplugged ...
Jun 01, 2023Guru - Experienced User
what actual speeds do you get wired?
Are you using fastlane?
make sure the ex3700 is connecting to the 5ghz. 2.4ghz is sensitive to interference and its slow.
You might try logging into the router and changing the 5ghz channel in case t here is interference
