F33b
Mar 22, 2017Aspirant
EX3700 Disrupts My Wired Switch LAN
I have a COMCAST cable modem/router with four LAN sockets. Two connect directly each to one computer. Two connect to 4 port switches. My family has a network attached printer, several desktop comp...
- Mar 31, 2017
I powered down all my PCs, my switches and the range extender.
Then I reset my modem.
When I powered everything back up again, the range extender worked just fine, and so did my wired network.
I'm guessing I forced an IP address change that fixed the problem.
DarrenM
Mar 31, 2017Sr. NETGEAR Moderator
Hello F33b
Did you make sure you have updated the extender to the latest firmware? also you may want to try and reserve the Ip address of the extender in the router.
DarrenM
- F33bMar 31, 2017Aspirant
