F33b's avatar
F33b
EX3700 Disrupts My Wired Switch LAN
I have a COMCAST cable modem/router with four LAN sockets.  Two connect directly each to one computer.  Two connect to 4 port switches.  My family has a network attached printer, several desktop comp...
  • F33b's avatar
    F33b
    Mar 31, 2017
    I powered down all my PCs, my switches and the range extender.
    Then I reset my modem.
    When I powered everything back up again, the range extender worked just fine, and so did my wired network.
    I'm guessing I forced an IP address change that fixed the problem.
