Kapurnicus
Aug 24, 2016Guide
EX3700 extender 5ghz won't both connect and repeat simultaneously
For some odd reason, I believed I should be able to connect the extender to the 2.4ghz and 5ghz bands in my home, and then repeat them both. It seems this is a challenge. If I connect the 2.4ghz and ...
DarrenM
Aug 26, 2016Sr. NETGEAR Moderator
Hello Kapurnicus
Have you tried to lower the wireless channel of the 5ghz?
DarrenM
Kapurnicus
Sep 06, 2016Guide
I have not. It is somewhere in the middle right now. I will give that a try. Can you explain why that should matter?
