icelandd
Oct 09, 2016Aspirant
EX3700 incorrect password
i just got my range extender and conected it to the router with wps.... i did it twice because the router has 2 and 5 ghz..... i now see the new wifi... 2GEXT and 5GEXT but when i try to connect i...
DarrenM
Oct 11, 2016Sr. NETGEAR Moderator
Hello icelandd
Have you tried using your main routers password? if thats not working you may have to do a factory reset and do the setup again.
DarrenM
- icelanddOct 12, 2016Aspirant
Hi Darren.
I have only one router. And i have tried the routers password 100 times but it always says inncorrect password. I have done factory reset twice but it dosnt help.
