icelandd
Oct 09, 2016Aspirant
EX3700 incorrect password
i just got my range extender and conected it to the router with wps.... i did it twice because the router has 2 and 5 ghz..... i now see the new wifi... 2GEXT and 5GEXT but when i try to connect i...
DarrenM
Oct 11, 2016Sr. NETGEAR Moderator
Hello icelandd
Have you tried using your main routers password? if thats not working you may have to do a factory reset and do the setup again.
DarrenM
icelandd
Oct 12, 2016Aspirant
Hi Darren.
I have only one router. And i have tried the routers password 100 times but it always says inncorrect password. I have done factory reset twice but it dosnt help.
- DarrenMOct 12, 2016Sr. NETGEAR Moderator
Hello icelandd
Do you have your password security set as WPA2?
DarrenM
- icelanddOct 12, 2016Aspirant
I think it is web (wireless key)
10 digital number
Hello icelandd
That could be the issue that the router is WEP try changing the security to WPA2 and then connect the extender.
DarrenM
