icelandd
Oct 09, 2016Aspirant
EX3700 incorrect password
i just got my range extender and conected it to the router with wps.... i did it twice because the router has 2 and 5 ghz..... i now see the new wifi... 2GEXT and 5GEXT but when i try to connect i...
icelandd
Oct 12, 2016Aspirant
Hi Darren.
I have only one router. And i have tried the routers password 100 times but it always says inncorrect password. I have done factory reset twice but it dosnt help.
DarrenM
Oct 12, 2016Sr. NETGEAR Moderator
Hello icelandd
Do you have your password security set as WPA2?
DarrenM
- icelanddOct 12, 2016Aspirant
I think it is web (wireless key)
10 digital number
- DarrenMOct 12, 2016Sr. NETGEAR Moderator
Hello icelandd
That could be the issue that the router is WEP try changing the security to WPA2 and then connect the extender.
DarrenM
- icelanddOct 13, 2016Aspirant
My routers name and modell is
Technicolor TG789vac
i talked to my service provider and he says that the router is pre sett to WPA2.
