swebs
Mar 31, 2019Aspirant
Ex3700 lan port not working
When I connect to the extender via WiFi with my laptop I can connect and surf the internet fine. When I connect any device via the device/lan port I can't get to the internet. It was working for ab...
schumaku
Apr 01, 2019Guru - Experienced User
When I have it right you can define to which of the two networks (2.4 GHz or 5 GHz) te LAN port is mapped to.
Check the extender Web UI is both bands are up connecting to the primary router.
swebs
Apr 01, 2019Aspirant
I'm not using WiFi I'm connected directly to the lan port
- schumakuApr 01, 2019Guru - Experienced User
swebs wrote:
I'm not using WiFi I'm connected directly to the lan portIt does not matter of the clients are connected to the extender wireless access point radios or to the LAN port - the MAC address translation will happen anyway.
swebs wrote:
When I connect to the extender via WiFi with my laptop I can connect and surf the internet fine. When I connect any device via the device/lan port I can't get to the internet.In either case, the LAN port will be bridged trough a WIFi connection - unless the extender does run in FastLane mode, it's configurable which uplink band is used:
Should this band not have an uplink connection - here it's the 2.4 GHz which as none (so the above does work) - the LAN port would not have a connection to the primary router and the Internet.
Information about details are everything - without it's hard to help.- swebsApr 01, 2019AspirantWell it works when I connect to it over WiFi but not through the port. I'll check the settings.
