AVJohnnie
Dec 19, 2015Tutor
EX3700 problem - Constantly requesting IP from router
I recently purchased two Netgear Wi-Fi range extenders - a EX6150 and a EX3700. The EX6150 is working perfectly. The EX3700, however, is constantly requesting an IP assignment from the R7500 router (...
- Dec 20, 2015
Tried resets - restore to factory - problem continued to persist ... also discovered that it was temporarily dropping clients when the IP request renegotiated. Decided to not take any chances - Returned and exchanged for a second EX6150...
Should have the replacement EX6150 in a couple of days - Amazon is fantastic!
AVJohnnie
Dec 20, 2015Tutor
- AVJohnnieDec 27, 2015Tutor
Second EX6150 working perfectly - I don't know if this is a common problem with the EX3700, I presume not since I could find no other references to the issue. I'll chalk it up to it just being a bad new,out-of-box "experience" and let it go at that - though I will not be trying another EX3700 at some point in the future because the EX6150's work so exceptionally well...
Cheers!
