Kriss60
Feb 07, 2017Aspirant
EX3700 Router Link Light
I am currently using a Virgin media super hub set to run on the 5Ghz band, but have a low signal in areas on the first floor of our house. I have set my EX3700 extender up according to the instruct...
- Feb 10, 2017
Hi Darren,
Thanks for the reply. I have carried out a factory reset and set extender up via my PC with the same results even with the unit next to my router. Checked router logs and it seems the extender i
keeps trying to obtain IP address. Have returned it and received a replacement which seems to be working fine.
Thanks for your help.
Chris.
DarrenM
Feb 10, 2017Sr. NETGEAR Moderator
I would try to factory reset the device and do the setup again in the same room as the main router then I would try to move it to the area you want it. If it is still doing the same behavoir I would then suggest to contact Netgear support.
DarrenM
Kriss60
Feb 10, 2017Aspirant
Hi Darren,
Chris.
