aliciab
Dec 27, 2018Aspirant
EX3700 set up - password
I am struggling to set up my new EX3700 wifi rnage extender. I have followed the quickstart manual for both WPS and web browser setup can't get wither method to work. When I search for the wifi device, I never get the NETGEAR_EXT option, but instead see HomeWifi_2GEXT. I chose that network because it is my only option but wonder if that is where my issue is. Can anyone help?
If you reset the extender with a paperclip, the HomeWifi_2GEXT network should disappear, and the NETGEAR_EXT should appear. Join that, and then use the web browser setup method.
The full manual might be more useful than the quickstart guide. It's here: http://www.downloads.netgear.com/files/GDC/EX3700/EX3700_UM_EN.pdf
- aliciabAspirant
Thank you- that was helpful!
